G2G printable map
A good friend of mine and her friends are planning on cycling the G2G from Floradale to Goderich. They are relatively new to cycling and will not have a phone with them (Mennonite).
I would like to print them a map of the trail and the detours, places to stop, etc. but can’t find anything online.
Is anybody aware of a printable map? Have a printable map?
Cheers and thanks
https://www.google.com/maps/d/u/0/viewer?mid=1hf9AqMFQ6V1kisujBKrhmtgijmQ&ll=43.56174337417728%2C-81.20867351725444&z=9
the above link is from the G to G rail experience web site and should link to the map. I think its printable. There are a few notable detours along the way including right in Goderich where the bridge is out.
Thanks Peter
EDIT…figure out some work arounds. I’ll zoom in and try printing it into sections.
Figured something out.
I saw that map on the g2g website. However the ‘print’ feature isn’t a great outcome. It basically just prints what you see…including the satellite view (which isn’t ideal printed out and i can’t find a way to turn it off!).
I tried opening it in Google Earth (as that option is available) and while i can get it to Map view…I can’t find a way to clean up all the distance tags.
If you scroll to the bottom of the panel on the left side there is a little square that will display the google maps base map instead of satellite view. If you’re stuck printing off sections of the map you might find it more useful to create a route in RideWithGPS instead - at least that way you can create a cue sheet with directions.
