I’ve just been getting back into cycling this year and have just been coming out to rec gravel rides with t-shirts. I was looking at jerseys from MEC and they’re all a little too athletic/form fitting for my body (240 lbs with a pretty good size gut)…
Anyone have a recommendation for where to pick up a jersey that might fit a bit more generously?
You can try mountain bike jerseys, fit a bit looser. Bicycle Booth sizing is more realistic compared to Castelli. 4X is actually baggy
Thanks Bob, good advice and thanks for the Bicycle Booth recommendation - will check it out!
Check out the Quest jerseys from pearl Izumi as well. I recall them having a relaxed fit, almost a 0.5 fit larger than regular fit. And they aren’t castelli tight to begin with.
I had good luck with Granny Gear from the UK as a taller guy.
