Transporting bikes inside car. take brake rotors off or leave on?
Planning a winter trip to Tucson AZ in February 2027. Trying to avoid having them on the hitch mounted carrier for the trip across the country. We maybe able to make it work. I did a test fit on the weekend. It’s my M/L revolt, and wife’s 54cm Trek Domane AL5+
Would you recommend taking the rotors off the wheels? I saw a youtube video about ‘axle protectors’ made from cardboard. I may do that as well… getting 4 wheels inside the car takes up a decent amount of space.
Assuming your rotors don’t touch chains with lube on them, and you aren’t putting heavy things on them, leave them attached. You are more likely to contaminate them by taking them off. I travel every weekend in CX season with multiple wheels, bever had an issue with rotors.
The only reason to cover the axles is to keep them from hitting the frame; it’s more of a flying and baggage-handler issue.
If you are taking wheels off, I would put spacers between the brake pads, assuming they are hydraulic brakes. Cardboard works. With bikes stacked, I would be most concerned about the derailleur hanger. It may be worth removing the derailleur regardless; always travel with spare hangers. They can be hard to source and ruin a trip in an instant.
Thanks Robert.
Is there likely to be an issue with indexing the rear derrailleur if I take it off the hanger? Both bikes shift well right now.
I am going to buy a cheap eggrate foam mattress topper and cut it up and use that for padding between the bikes and wheels.
The Dolmane+ AL5 is heavy with the battery and the rear hub motor, so that one goes on the bottom. The Giant Advanced Revolt is light in comparison. I think for the trip, I was experiment with having the bike then wheelset on top, then bike and wheelset on top again. With the rotorside down on the 1st bike, but centered in each of the triangles of the main frame…
I think we’ll save about 10% efficiency having the bikes inside the car for the cross-continent trip, which is important when EVing…
As long as you put it on as it was taken off, there is zero issue with indexing. If you know nothing is touching the derailleur, I’d leave it attached if you aren’t sure.
I wouldn’t worry about wheels, aside from scratching paint they are unlikely to do any damage. Biggest reason for bikes inside is salt spray on the roads. This will cost you over time, even if you don’t realize it now.
@Petee can confirm the EV efficiency loss… I wouldn’t want to go cross-country with a bike rack on my EV. At lower speeds it’s OK, but at highway speeds I lose much more than 10% range.
I’ve actually been pleasantly surprised hauling my bikes on a rack on Polestar 2 EV even at fast highway speeds. I don’t think I lose as much as 10% but it is hard to know for sure.
But when it is just one bike I do keep it inside both for efficiency and safety. I bought a large moving blanket which does an excellent job to separate the bike from the wheels. I never pull off the rotors but always have them facing up and ideally on top of everything else.
been to Granby, QC in June 2026 - got about 25.5 kWh/100km with 2 bikes on the back (avg speed 103.5kph) - mostly 401 (left from son’s place in GTA) and 24.6kWh/100km on the way home to Wloo area. (avg 96.5kph on the way back)
been to Lindsay, ON in September 2026 - got 22.1kWh/100km with 2 bikes on the back - mostly 401 (but likely slowdowns in GTA - avg speed 103.5kph)
  • on the way back, we took the scenic route north of toronto 70kph avg speed, consumption was still 24.5kWh/100km
Cottage trip to Gravenhurst in June - got 20.7kWh/100km - no bikes on the back, leaving Wloo area ~821pm 401-407-400 (avg 104kph)
Yeah, I geek out.
