Hitch mounted carrier…
How bad is this for the bike? Dreaming about spending some time in Arizona next winter…
My bikes see a lot of time on a hitch mounted rack. (Tray style). You can get some road debris thrown at the bikes when in bad weather, but I’ve never had issues from it.
Bigger concern is to be sure you have visible tail lights on the vehicle. Hitch racks often cover them.
Biggest issue is salt spray, that is generally a Ontario and northern states issue. I’d give a it a full clean on arrival.
Definitely get a waterproof bike cover if you can’t fit the bike inside (this one is $55 on Amazon):
The other option is to go with a vertical bike rack. I started with a rear hanging bike rack, then upgraded to a Yakima Fourtimer tray bike rack, and finally upgraded to an Alta 5-bike vertical bike rack. In hindsight I should have just bought the Alta in the first place. I sometimes need to carry more than 4 bikes though…
The advantages to the vertical racks are that they
But they do have downsides
Just clip two blinking cycling red lights onto the bike cover ![]()
Kidding…don’t do that!
I’d say those taillights are pretty blocked anyways. I’d be more concerned with the drag.
I ended up with a 1up rack several years ago, nice thing is for a little extra I added a light bar to the rack. Seems Thule is starting to add them. 1up is expensive but the tray racks are the fastest on the market and if you damage it every part is replaceable, that has saved me ditching a rack that was 90% serviceable after clipping a post
One thing to be aware of – technically, you can be ticketed using this style of carrier if it obstructs your license plate. Given how popular these are, I can’t imagine that happens very often. And, I have no idea what the legalities of these are in the US!
See this Globe and Mail Q&A on the topic: Can I really get a ticket for having a bike rack on the back of my vehicle? - The Globe and Mail
I wonder if I can shoehorn the bikes in the back of the car (it’s a hatchback) for the trip down.
Remove:
Wrap the frame in foam.
Both our vehicles are EV’s so, they are very dependent on aerodynamics for range. Plus the cold in February won’t help, especially for the 1st day of travel. Leave the rack on the back but either folded up or flat..
Need to leave room for the dog… Could be super tetris getting everything settled.
Might leave the bikes assembled on the racks on the trip home as we will have prevailing tailwinds.
I managed to fit both a hardtail mountain bike and a gravel/cross bike in the back of an RVR to drive to Arkansas in February 2020.
I left the rear hitch rack at home for cleanliness and security (like when you have to go eat on the road and your bikes are out there). Overnight while driving there and back, I brought them into the hotel room too.
Sounds like maybe your hatchback is smaller? I had both front wheels off, but otherwise not much else. Soft-sided luggage can sit on top. Old sheets and blankets in between the bikes and wheels and luggage. Lots of smaller pieces are easier to Tetris in the back than a few large suitcases, etc.
This was the load when we left Arkansas:
In case it helps, I’ve also travelled with bikes in the car. I found two small purchases really helped to avoid any damage.
If you’re willing to take off wheels and rotate handlebars, have you considered a roof top box with some bubble wrap/blanket?
Bonus…you can use the roof top box for other things (e.g. camping!)
They are relatively aerodynamic too…i don’t see much of a hit to my fuel economy with mine. Decent Thule that should hold one frame with two wheels or two frames and maybe one set of wheel is about $500-600 ish?
The Kuat has LED brake/indicators built into it. One of the reasons I bought my 4Runner was 2 bikes fit inside (standing upright) and 2 on the rack lol
We have a Thule roof top carrier and have fit a 29er in there with the front tire off and handlebars off. Can then put other bike in back of car and put soft luggage around each. Our carrier also locks. It would reduce your range I’d think though.
Dawn
